A Japanese dealer bought the Airbow grounding box. He felt that its sound quality was more luxurious and smooth than many Swiss Lenon and domestic bra
honghonghuo
A Japanese dealer bought the Airbow grounding box. He felt that its sound quality was more luxurious and smooth than many Swiss Lenon and domestic brand floor-standing speakers.
There are more than a dozen eBay.
As a brand, Airbow can optimize the performance of its products and experience improved sound quality if it focuses on the careful selection of details and materials in the field of audio.
The main function of the audio ground box is to provide a good grounding environment for the audio system, reduce electromagnetic interference, and thus improve the purity and dynamic range of the sound quality. A well-designed ground box can effectively isolate external noise, enhance the detail expression of music, and make the sound more natural and delicate. This feeling of "nobleness" and "smoothness" is often reflected in the subtle levels of music, the separation of instruments, and the overall openness of the sound field.
If Airbow's ground box can show excellent performance in these aspects, then it uses the following features or technologies:
- Highly conductive and low-impedance materials, which can conduct current more efficiently and reduce signal loss.
- Precision internal structure design, multi-stage filtering, special shielding technology, etc., to more thoroughly eliminate interference.
- Ensure the purity and directness of the grounding path to reduce the noise caused by the grounding loop.
- Use damping materials or special designs to reduce vibration and further improve the purity of the sound.
The effect of the floor box is mainly reflected in the background being quieter and darker, and the separation of instruments and vocals is better. The expressiveness of details is stronger, especially the details of weak sounds, the low-frequency dive is deeper and clearer, the guitar plucking feeling and the violin string pulling feeling are very vivid and more dynamic!
Honestly, as far as I'm concerned, I can say that part of the problems lie in the quality of the audio cables. You don't need exceptional cables that cost a lot but good quality cables are enough. For example, by replacing a small cable with one sold by Fosi Audio I eliminated a small background noise spending very little
