Can I use a 6 inch 3 ohm subwoofer with BT30D Pro
vineeth.nair
Hi,
I recently bought a BT30D Pro, using with my 6.5 inch 4 ohms bookshelf speakers which can produce 40W each. I also have an old SONY 6 inch 3 ohms sub-woofer. I see BT30D Pro can work with 2-8 ohm impedance from the specifications, still I need an expert opinion about using the 3ohm 6 inch subwoofer. Or should I move to a 4ohm larger sub-woofer. (Note: I don't prefer much bass from the sub-woofer)
