Co-Create DAC/3-way crossover for DIY Open Baffle crowd
ChefBrunch
Imagine If you will.
A DAC with High , Mid and low range analog stero outputs.
Similar to a loudspeaker driverack that DJ and PA systems will use, But the DAC is on board and all the EQ is done in the first digital steps. Cutting out a conversion step used in a driverack.
Your inputs are the basic digital inputs, Coaxial,Optical,BT,USB
your analog outputs are 3 pairs of stereo RCA , Highs , Mids , And Lows.
The Front control panel has a master volume , Highs,Mids and low trim pots, along with source selector.
RCA and not balanced XLR to keep form factor small and cost down. A lot going on in this potential device.
I think this would be a very popular piece of budget kit for the people that want to try building their own open baffle speakers. And or another way to use other small amps they may already have laying around.
Just an Idea I had for a nice Fosi piece of Kit
Can name it the Fosi DAC-OB3 for open baffle 3 way DAC
