LC30 Issue
f1jimbrown
What is never mentioned in any of the reviews for this product is the hookup issue that requires splitting the source output with a Y cable to both amps you are switching between with the LC30. When I split the output of my preamp with a Y cable the second I plug the output into the 2nd amp the volume drops dramatically. Same if I use separate output RCA's to each amp. To confirm this, with everything hooked up and system running on amp one, unplug the source RCA to amp 2. You should notice the volume drop significantly.
