Pair of V3 monos no audio output
Monkey96
Hello all. A strange occurrence here.
I have a pair of V3 monos with separate 48v/10a PSUs. It's fed by an RME DAC via XLR.
I set them up yesterday and was immediately impressed with them. I added heatsinks to the tops of the cases to keep them nice and cool. All good.
Today I messed around with my speaker positioning and had a good listening session, then later switched off the music and watched the TV (also running through the DAC). All good.
I then realised that I hadn't put the DC filters in the chain, so switched off the V3s, added the filters in the chain, and then powered them on.
No audio output from either amp.
So I switched them off, disconnected the filters, and reconnected the PSUs.
They power on as usual, speaker circuit check relays click, RCA to XLR selector relays click, LEDs on; all fine. But no audio.
Everything else in the chain is fine. DAC showing signal (it has a display on it which shows all is normal). No loose connections. When I power on the amps, there's even the normal 'pop' slightly audible through the speakers. But no audio.
Any ideas anyone?
I have emailed Fosi but thought I'd ask on here.
Thanks.
