Phono Preamp Phono ADC
Aswego
A phono analog to digital pre would be a very good addition to the Fosi line up. I found a few.. one from Project and one from Thorens. I would like to use my turntable with my ZD3 and keep the Fosi Aesthetics.
I'd love to see this. RAC input, grounding wire, USB output. And powered by the USB. Like the Behrigher UFO202, but not so ugly.
I have a UFO202. It has a level control, which I always have at full, so I'm not sure what the point of it is. Also a line/phono switch might be handy. A MM/MC switch might be handy for some people.
Sorry, we would like to ask why you want USB power supply?
UFO202 should support both MM/MC player inputs, right?
Do you think there are any other bad features besides UFO202 that are not very attractive?
USB power supply to reduce the ridiculous number of plugs and sockets I have around my desk - 12 at the moment. Since it would be plugged into a PC USB and not draw much power. why add a plug and a power brick?
The UF0202 only supports moving magnet.
A well known Hi Fi mag was less than impressed, "Rudimentary organisational skills, Does not time well"
but I suspect that is more snobbery and a lack of advertising spend. It sounds fine to my ears.
The UF022 case is very cheap feeling 'metalic' plastic, its really light slides around unless jammed in somewhere. Next to a nice turntable it just looks and feels nasty.
Looking at the Cosmos ADC, reviewed on Audio Science Review E1DA Cosmos ADCiso It could almost be an early Fosi product. If it was given an nicer case and a bit of Fosi brand polish it could be a great addition to the range.
