Replaceable Cables 48V/10A GAN Power Supply
SeVen-SeVen
Hello Fosi team,
You have developed a really great power supply and filter. What would really top it off is if the power cable from the power supply to the filter could be replaced with a higher quality shielded cable, for example. The Y-cable between the filter and the V3 Monos would also be desirable if you could offer a better one for an additional charge. The sound could be "tickled" a bit here. I have already connected a very high quality Tertullus P029 (double shielded, 3 wires of 4mm) to the power supply itself. The improvement in sound was enormous. The V3 Monos, for example, have much stronger mids and distort much less at very high volumes.
