Co-Create Subwoofer amplifier with V3/P3 form factor, phase control and correct frequency control
onceKilos
It would be very nice to have a subwoofer amplifier with a phase control, a knob with 0 to 180 would be awesome (or at least a swtich for 0 or 180) to blend it with the current audio systems
Also a good and functional frequency cut control that works properly, the one on the TP-02 doesn't work, even if you put it to the minimum cut it still let pass frequencies up to 200hz, and some above as well
The amp should be able to take stereo XLR/TRS and RCA input, sum to mono, but also pass-thru stereo or mono via XLR/TRS and RCA.
*It has to provide a real -24db cut off filter under 40hz to 120hz about.
*re design the case with more holes on the top because of more heat génération with low frequencies
*ensure that it can hold long time signal at 2 ohms without going in security mode
*Make a versatile amp than can be used later in little PA sound systems, portable sound systems on 24v or 32v mode...
