DAC ZD3 firmware 1.07
newfosi
I was advised by Fosi Support to install firmware 1.07 to cure an echo/buzz issue. They attached a zip file and a link to a google drive folder with the same files. The instructions call for installation of a .bin file called update_spdif_noise_fix_zd3.bin. But that file was not present in the zip file or drive folder. Instead there was a file called update_zd3_revert 2025.1.22.bin.
Has anyone done the firmware update? If so, which file did you use, and how did it go?
Thank you
