ZD3 USB Input options
kmfkevster
I've just received a zd3 and a za3 that I want to connect my Eversolo Play to to bypass the Play's lackluster amp.
I want to output via the Play's USB audio out to the zd3 USB input since the Play has no analog out (otherwise I would have gone directly to the za3).
Will the zd3 recognize the the Play data stream? I see a lot of references to PC connection capabilities, but can't find references to connecting via USB with other devices.
The Play USB output supports up to Stereo DSD512 Native and PCM 768kHz 32Bit,, but coaxial is much lower, so I don't want to use it..
Will these devices be able to talk to one another?
I neglected to mention that the Play is built around a customized version of Android 11.
