ZH3 cuts off first bit of audio (Less than 1 sec)
FawzyS
The ZH3 is connected to my MacBook Pro via thunderbolt and playing through Sennheiser HD598's. It cuts off the first few tenths of a second of sounds that it is beginning to play. I am CERTAINLY willing to concede that I may not have everything connected properly.
I really like the sound (once it starts playing) and don't want to send this back. Any advice on things to try?
Fawzy
This actually seems to be a common issue with most modern DACs and it has to do with how they handle audio streams and going to sleep when there is no signal.
When using the ASIO driver, there is a hidden setting in the driver that you can enable, which prevents sleep and is known as always-on streaming.
Not sure how that works for Mac.
For Windows, you can use https://github.com/vrubleg/soundkeeper to output a continuous but silent stream to the DAC, preventing this issue from occurring.
This fixed my problem on Windows with the ZH3 but I'm not sure if there is something similar for Mac.
When I'm editing, I add a track to my recording to send a stream of tone at something like -60dB to the device, and that helped. I'll see if there's something similar to the ASIO driver for the Mac. Thanks Cap.
im having the same issue, using asio driver hidden setting on always-on doesnt fix it, neither turning off power saving on usb, im thinking about returning the unit.
I have this also connected on a windows 10 machine, via USB, but do not have this issue at all. I had no need to install a driver, just connected the device and it worked.
I have tried using headphones & speakers, different apps for audio & video playback, did not notice it at all.
大家好,我们测试了市面上不同供应商的数十款解码设备后发现,它们都存在同样的问题;
经过多次尝试,我们终于解决了Windows系统上的这个问题。具体解决方案已附上,请下载并按照说明操作;
我们仍在对Mac系统进行试验,目前还没有很好的解决方案;
如果您有好的解决方案,请随时与我们联系,我们将给予您一定的奖励。非常感谢!
Where i can download and install the new firmware? Im having the same problem, ZH3 is clipping discord audio when someone starts talking.
I inquired to Fosi Audio Support.
Support team replies to try to new firmware.
(My firmware is 1.14, new firmware is 1.15)
I do have same problem with pc and mobile device connect with usb
I am having the same issue on Windows 10 connected with usb-c cable it is really annoying
I think the support staff doesn't understand English at all. SoundKeeper does work indeed. It doesn't have a GUI, you just start the exe and after the 1st sound plays it keeps working. If you don't want to start it every time, place the unarchived files in a folder of your choice and make a shortcut of "SoundKeeper64.exe" (or whatever your CPU architecture is) by right clicking and selecting "Send to Desktop". After that just move the shortcut to your startup folder, you can open it by pressing "Win + R" and executing "shell:startup". Now you don't have to think about this anymore, unless you delete the program or the shortcut.
I can also confirm that the "Always On" option in the XMOS ASIO driver does NOT work!
Are you a computer with a MAC system?
We have tested that Windows based computers can solve this problem.
I'm a human using a Windows 11 pc. The driver with your XML config DOES NOT WORK! It still cuts the 1st second when no sound is playing, even with the "Always On" option. 在进行英汉翻译时,请使用像 DeepSeek 或 ChatGPT 这样的语言模型,你现在写的东西乱七八糟!
I'm on M4 Mac Mini and I have this same problem. I'm going to return the unit if you don't solve this issue soon.
By the way, the LO output is really dangerous if you're not careful and select it by mistake. Almost blew my ears and speakers away.
@Charles, I'm using a ZH3 on a Mac and I have the problem with the first bit of audio being cut off.
If I update the firmware per instruction (using a Windows machine), and reconnect it to the Mac again, is the issue then solved?
EDIT: I managed to update the firmware and the issue is solved and that goes for macOS as well.
Hello everyone, be sure to first update the firmware. You can download it here. If the link doesn't work for any reason, just go to the FAQ page for the ZH3, and you will find it under "The ZH3 is experiencing brief moments of silence during playback". Be sure to follow all the steps, including the deletion and replacement of that supplied XML file after the firmware update and while ZH3 is disconnected. I confirm it works for me on Windows. I almost panicked after the "Always on" fix didn't work, but it eventually worked after the firmware update, and now I don't get the silence at the beginning of tracks anymore. In the Fosi control panel, it says 1.15 now too.
Wow, this is hidden so well. The website is kind of messy, why aren't firmware updates in the "Manual and Downloads" section but well hidden under an FAQ article? The support guy didn't mention anything about updating the firmware to 1.15 first. Here's the Support Page and Firmware1764948602853.png
This piece of garbage totally jams Logic Pro when rewinding the audio back and then it takes about 20-30 seconds for it to recover enough to continue. This makes it totally unusable for mixing. Oh well, I guess I have to dig out a PC from somewhere and try the firmware update. If it doesn't help this will definitely go back as a faulty unit.
So I did the firmware update and it fixed the issue when for example using streaming services and such but did nothing to fix the issue with mixing. So be aware that you might have severe problems if you try to mix with this piece on junk.
Same problem on Mac mini M4, was about to return it! but the firmware issue solved it (alhough you need a windows pc to upgrade?) Happy now!
I found a workaround solution for the Logic Pro problem. I run the sound through my SSL Alpha 8 interface and from there through coaxial output to Fosi. Now it works as it should and the sound is not cutting and jumping all the time. I reckon the DAC in Fosi was the weak link here for some strange reason. Mixing just using Fosi was downright impossible with more than average track count.
@Charles What does the change actually do? Is it a hardware setting or is it just a software setting via the driver?
I would like to use the ZH3 on different end devices.
PLEASE: Make this a menu setting inside the ZH3 itself which you can set via the knob or remote control. Just like Volume, Gain, Filter, ... ...
I’ve tried to update several times. Always “successfully”. But version still shown as 1.14 instead of 1.1.5/1.15.
Using both PC x64 win11 and MacBook Pro m1. Btw no sound with 1-st muted sec in my side.
I got it to work, not sure it missed 1s before but at least some audio
Could we get a faster screen turn-off? 2 minutes on is a bit excessive
I generally prefer 5s, but it would be nice to have it adjustable
Guys. My happiness didn’t last long with no clipping sound issue. I found my path with a clipping sound — and that is almost all the voices in the chats. Discord, direct voice chats in steam doesn't matter.
So from now i'm also in your club.
Any ideas how to successfully update to 1.1.5?
In my case, firmware update to 1.5 solved the issue with USB input, however this still persists with optical input.
Any ideas?
It will be great if someone tech from support come here and help. Looks like there are only marketing guys with no Eng. I've even wrote a feedback on main page. Let's see what will happen. Either respond to it or delete on pre-moderation. (https://fosiaudio.com/products/zh3-dac-headphone-amp-preamp)
I can only tell you now, that after upgrading, my ZH3 is working as it should, no skipping, autoswitch my Mac, and a very good sound + usability.
I just took delivery of a new ZH3 from Amazon and it shipped with the 1.15 firmware already installed.
I verified this using `fwupdtool get-devices` on Bazzite.
It would be great if Fosi made the firmware available separately from the windows driver.
Thanks guys, really glad that u didn't faced with same the issues. But i'm still waiting for response from fosi support. Mine upgrade unsuccessful up to present. 10 different cables, 2 AC blocks, all PC usb ports and result is always the same: "Firmware upgrade finish successfully", but it is the same 1.1.4
Wow, this is hidden so well. The website is kind of messy, why aren't firmware updates in the "Manual and Downloads" section but well hidden under an FAQ article? The support guy didn't mention anything about updating the firmware to 1.15 first. Here's the Support Page and FirmwareView attachment 2487
Thanks for posting this, I would have never found this stuff otherwise. I was able to update to 1.15 flawlessly.
If anyone is having trouble, read both of the docx files very carefully!!!
Hi Guys!
I recently bought Fosi ZH3 DAC - great little tool, I must say. I really like how it sounds, especially with external (better) power supply. The firmware installed on my device is 1.1.5 (or 1.15 - not sure which one is correct).
The problem discussed here seems to be fixed when listening on USB input (from Wiim Ultra). Unfortunately, the problem persists when the source is connected via OPT or COAX input.
Can you please confirm it when using your devices? The "cutting off" problem is observed when watching anything, constantly, between dialogs, etc. On calm music, with moments of silence, as well. On USB input it's a great device - but on OPT/COAX it seems to be useless, unfortunately :(.
[...] Unfortunately, the problem persists when the source is connected via OPT or COAX input. [..]
This is exactly my opinion. I have confirmed this to be the case on both OPT and COA inputs, from 2 separate output devices (to rule them out). I am using the "fix" firmware 1.15. The bug is in the ZH3.
Attached is an MP3 that clearly shows the problem. Play it back at the source, connect via OPT or COA to ZH3. The first "click" is heard, the remainder of the MP3 is silent.
Fosi Audio, please promptly publish a fix for this bug in your product that fails to correctly play back S/PDIF streams via the OPT or COA inputs.
I tried following this but then the firmware update said that it failed. Then my ZH3 wasn't able to be detected. I tried reinstalling the drivers, rebooting my PC multiple times, using different USB cables, and trying a different computer entirely but it's been unable to be detected on device manager entirely. The screen still turns on fine and I've confirmed that it's on USB input mode but it still can't be found for some reason. The Fosi audio control panel also says no device connected
