You mean when you select it via the remote, right? For whatever reason, it resets to a random filter when I click the filter button on the remote. When I go to the filter menu using the knob, it doesn't do that. Either way, it does save and remember whatever the filter I set it to, via the remote or otherwise. Using the knob, I can verify the setting is in fact saved. It's the clicking of that button on the remote that resets it.
