Preamp ZP3 thoughts and concerns
newfosi
I've ordered a ZP3, which is expected to arrive tomorrow. FedEx consistently gives inaccurate arrival info (it was originally supposed to arrive yesterday), so we'll see.
I checked with Fosi customer support on op rolling. The ZP3 op amps are socketed, so op amp rolling is possible, but unlike the other products in the "Z" line, Fosi is not touting that capability. I believe the case is difficult to open and has a warning about doing so given the interior power supply.
The image of the case construction on Fosi's web page shows the case's side panels are screwed to the case, but the actual product images show the side panels have no screws. I read elsewhere that the panels are glued on. I checked with Fosi and they said the side panels require a special tool to open. Once it arrives I'll ask them to explain what the tool is and how to open it.
I bought two Sparkos SS3602 amps, which I put in my ZD3, but since I am replacing the preamp function with the ZP3 I would like to move them from the ZD3 to the ZP3 if possible.
I agree with criticisms I've read regarding the infinite volume knob, but I don't think it will be a big deal given that I only use one input - the ZD3 to the ZP3. But I liked the ZD3 volume level screen and will miss it.
A bigger issue for me is the ZP3 remote. I will probably go back and forth between the ZD3 and the ZP3 remotes. The ZP3 remote has a ZD3 button that converts the remote to a ZD3 remote to change inputs on the DAC. But the ZD3 screen's input indicators is not legible from a distance. The ZD3 remote resolves that issue with dedicated input buttons. But the only input buttons on the ZP3 remote are "ZD3" and "Mode". I assume once I press the ZD3 button I can cycle through the inputs by pressing the Mode button repeatedly, but selecting a specific input on the ZD3 remote was a better way to do it.
I'll update with further info when the ZP3 arrives.
Just wanted to list the reasons I ordered the ZP3.
1. I have two ZA3s in mono mode connected to a ZD3, and a V3 Stereo amp in a separate room.
2. The Z products are all connected via XLR. I have no idea if that improves the sound but I noticed that a balanced connection provides higher volume at a lower volume setting than RCA for these components. Plus I just like the way XLR cables connect securely to the components.
3. Separation and clarity are excellent. A big improvement over my prior Sonos amp.
4. Fosi prices are very affordable compared with comparable big name brands.
5. Fosi's customer service is good. I've always received rapid responses to my questions.
But as a "nice to have" feature I felt that I was missing a tone control. Finding a tone control that supports XLR is hard to do at a reasonable price point. I could have gotten a Schiit device but that meant switching to RCA.
So I was interested in the ZP3 because of my satisfaction with Fosi so far, the XLR support, the tone control, the HPF and the price after early bird discount. If it turns out I can move my Sparkos op amps from the ZD3 to the ZP3 that would be perfect.
Let’s start with my electronics pre-ZP3
1 Q70 Samsung TV
2 Apple TV connected to the TV by HDMI
3 ZD3 connected to the TV by HDMI ARC
4 ZD3 connected to two ZA3s in mono mode via XLR cables and trigger cables
5 Sparkos SS3602 (2) replaced the stock XLR output op amps in the ZD3
I’ve now added a ZP3 connected by XLR cables to the ZD3 and the ZA3s. The preamp in the ZD3 is bypassed. The subwoofer cable is moved from a ZA3 to the ZP3 and the HPF is set to 80hz.
The good: bass is improved even without adjusting the tone controls.
The bad: overall audio quality seems like a step backward. I suspect the reason is that the Sparkos op amps are still in the ZD3 but the ZD3’s preamp is bypassed. As yet I don’t know the proper way to open the ZP3 case and move the op amps.
Other
1 Volume control with the ZP3 works worse than the ZD3 remote. Volume changes work instantly on the ZD3 remote. Not so on the ZP3. The first press of the ZP3 volume button appears to do nothing. Perhaps it creates a connection to the ZP3. There is no way to prove that other than my own ears but I don’t hear any change on the first press. It creates confusion. The ZD3 remote doesn’t do that. The ZP3 mute button works on the first press, so I don’t understand why the ZP3 remote volume button works differently.
2 The Z P3 remote has a button to convert it into a ZD3 remote and another button labeled Mode. If the remote is used as a ZD3 remote, you can press the mode button to cycle through the various digital inputs in the ZD3. But if you are sitting on a couch a few feet away from the ZD3 you can’t see which input is activated. It’s much easier to choose inputs via the ZD3 remote rather than the ZP3 remote set to ZD3. That means it’sbetter to juggle two remotes.
3 It’s necessary to choose inputs on the ZD3 because my TV is connected to the HDMI input on the ZD3. I use the Apple TV remote to control the TV. But when I use the Apple TV remote to shut off the TV it also shuts off the ZD3 since they are all connected via HDMICEC. There is some quirk between Fosi devices and the Samsung TV that causes the ZD3 to wake up 30 seconds after shut off, and that turns the TV back on. The fix is to change the input on the ZD3 from HDMI to something else, and then shut off the TV. And also shut off the ZD3 separately using the ZD3 remote.
Because the ZP3 remote only has a single mode button, cycling through all of the inputs to get to HDMI to turn my system back on is an annoyance. So I choose to use the ZD3 remote to press the dedicated HDMI button so my TV audio is played through the ZD3.
Also, since the ZD3 preamp is bypassed, the volume button on the Apple TV remote accomplishes nothing. I can tell from the ZD3 volume display that it is changing volume, but the ZD3 volume control is bypassed. The ZP3 controls the volume, but the ZP3 is not part of the CEC daisy chain so can’t be controlled by the Apple TV remote.
4 The end result of the above is that I need a minimum of three separate remotes. The ZP3, the ZD3 and Apple TV remotes.
These various annoyances would be tolerable if I felt that the overall audio quality was meaningfully improved by the addition of the ZP3. But so far that has not been the case other than a noticeable improvement in bass. Perhaps the ZP3 needs time to break in. Or maybe I will see a video online of a brave soul who dares to open the ZP3 case and is willing to share how to go about it.
Thanks fester70.
My understanding of the ZP3 bypass is that it turns off the tone controls, which is one of the two primary reasons I bought the unit.
I also noticed I get a ground loop hum when the ZP3 is installed. No hum when it's disconnected. I haven't identified the source of the problem yet. Might be the difference in ground paths (ZP3 power cord uses a 3 prong plug vs. 2 prong plug for the other Fosi components).
I plan to return the ZP3. Even if I can swap the op amps from my ZD3 (they aren't doing much in the ZD3 when I bypassed the ZD3 preamp to use the ZP3 preamp) there are too many other annoyances.
I didn't realize how much I would lose by subordinating the ZD3 to the ZP3. I like the ZD3 volume level screen, the dedicated input buttons on the ZD3 remote and the ability to control my system with one remote via HDMI CEC. Plus it sounds great.
I read your linked post. Can you describe what was necessary to peel the side panels on the case? Just curious. Are they glued on? Can you put them back on after you're done?
I've reported that when I turn the volume all the way down Instill hear music. Also, when I start increasing the volume, the starting point is too high. I've been asked to send a video and connection pictures, but I know what I do, I didn't connect anything wrong. I plan to return it as well.
How much voltage are you feeding into the ZP3 from your dac? Mine is getting around 3.8 Vrms (FiiO M17) and is dead silent with the volume down.
I couldn't say. How can I check that? I have the wiim Ultra and the SU9 at full volume.
Looks like when it's set to fixed output the SMSL SU9 has the standard line output of 2 volts for RCAs and 4 volts for XLRs but then XLRs go up to 5.3 volts if you're using the volume control.
So... the first thing to try would be to just set the SU9 plugged into the ZP3 at fixed output, which likely is the setting where it objectively performs the best (highest sinad, lowest noise and distortion) then can try lower volumes below that as necessary.
I did not swap the op-amps in the ZP3, I use the pre-amp as a switcher for an ipad, turntable and tv. The ZP3 XLR outputs to analog to digital converter to the ZD3 DAC (bypass), which has the virtual hifi supersonic v2 op-amps. The ZD3 XLR outputs to ZA3 XLR inputs out to Audioengine passive speakers.
I've been thinking about since the video guide Fosi provided shows it with the Sparkos ss3602 but honestly have no issues with the sound with the stock opamps and the swap isn't exactly easy. Would likely have to get a few new tools too.
I just got my ZP3 and am having a horrible experience. I have it between my ZD3 and two ZA3 amps in a monoblock configuration. I am hearing a rather loud hiss when nothing is playing. When using the ZD3 as the preamp in my system, the "background" was completely silent! I played around with changing things around in order to isolate what might be causing the hiss and discovered that the hiss only is present when the tone controls are NOT bypassed (bypass switch set to "off"). When I switch it to bypass mode, the background is completely silent again!
I tried plugging the ZP3 into a different power strip than all the other gear in my system and nothing changed. The hiss is there across all three inputs. The hiss does not change with volume adjustments on the ZP3. It does not change when adjusting the tone control knobs back and forth either. It is there only if the tone bypass switch is set to off (i.e., tone controls enabled) and completely silent when tone controls are bypassed. Even with the ZP3 in bypass mode, I feel that there is a decrease in sound quality from my system compared to my previous setup using the ZD3 as the "preamp".
BUT!!!! Through my troubleshooting, I discovered that the hiss is not present (regardless of bypass switch position) when using only the RCA outputs to the ZA3s. By only changing the connection from the ZP3 to the ZA3 amps from XLR to RCA, the hiss is eliminated entirely, the tone controls work as expected and the sound quality seems to be significantly better! Only when listening to the ZP3 over RCA out did I realize that even when playing music over the XLR output, there is a slight audible hiss in quiet portions of songs. I was shocked to discover that is completely removed when using the ZP3 over RCA.
So, apparently, there is something wrong in the ZP3's XLR output circuit and it has something to do with the tone control circuit's interaction with the XLR output.
I am very disappointed with the ZP3 and will be returning it promptly. On paper, the ZP3 was exactly what my system needed at a impressive price point (HPF, tone controls, R/L balance, XLR and RCA inputs, etc). Unfortunately, it appears to be a complete fail.
The replacement came today and it has the exact same issue! I tried using the new power cable with the new ZP3, the old cable with the new ZP3 and the new cable with the old ZP3. No change to the hiss / static sound. I even tried an entirely new surge protector power strip! The hiss is there regardless of the ZD3 being on or connected and the same is true for the WiiM. I connect the Wiim to the DAC via optical so it is for sure not a ground loop related to the wiim as it is electrically "air gapped" from the ZP3. With both amps turned on, the DAC on and the WiiM on but the ZP3 off, there is zero background hiss. As soon as the ZP3 turns on, the hiss begins. With everything on but the ZP3 not connected to the amps, there is no hiss. This tells me that it is not RFI around the devices interfering with the amps. No, the hiss is being transmitted over the connection to the amps from the ZP3. There is no change to the hiss when using or eliminating the Fosi DC power filter on the ZD3. There is no change to the hiss switching between any of the three inputs.
The new ZP3 has the same exact behavior as the old:
1. The hiss is louder when connected to the amps over the balanced XLR output rather than the RCA output. The hiss is quieter on RCA output but still present.
2. The hiss is louder when the ton controls are not bypassed (and quieter, but still present when the bypass switch is enabled)
3. Adjusting the volume on the ZP3 has no impact on the loudness or sound of the hiss. This tells me it is not related to the volume attenuator circuit.
4. Adjusting any of the tone controls when not bypassed has no impact on the hiss loudness or sound.
5. The HPF settings have no impact on the hiss loudness or sound.
I can "hide" the hiss by turning the ZA3 amps down from 100% gain and then compensating with turning the ZP3 volume up. Doing this means I have to precisely adjust the left and right amp to exactly the same level which is finicky but can work. Additionally, it adds attenuation to the signal path which is not optimal.
Unfortunately, this replacement is going back too. In this day and age, background hiss is unacceptable. I've never had an issue with Fosi gear but the ZP3 seems to be horribly flawed.
This sounds really strange. I am using the ZP3 with two V3 monos, using XLR cables, and have no hiss at all, regardless the tone control setting.
Though based on your troubleshooting, it does appear that it is the ZP3 that somehow causes the issue.
I wonder if there is any weird incompatibility when using the ZP3 and two ZA3s in mono mode, or if perhaps there is a batch of ZP3s that has some issue.
