Co-Create Co-Create FOSI AUDIO Txx
joqueval
Hello friends.
Another development by Fosi Audio could be the FOSI AUDIO Txx.
Fosi was developing support systems for the placement of devices with the option of forced installation using fans.
The Fosi Audio Txx would be a set consisting of a control unit that would have an information screen and configuration app.
This control center would be connected to the forced ventilation system (fans) by cable or by a wireless system that would not create interference in the audio system.
In the center, the speed of the fans and the working temperature of the systems could be configured.
For example, establishing a trigger system from a certain temperature and establishing the speed of the fans based on the increase in speed.
As the control system would be scalable and different fan sizes compatible with the equipment supports could be used, allowing different configurations to be made.
The wiring would be flat to allow discreet placement.
The speed and noise of the system would be silent and the power supply for the ventilation systems would be protected so as not to induce interference in the network due to the operation of the fans.
Greetings and I hope you find the ideas interesting.
