DAC help line noise reduction help
hello fellow FOSI Audiophiles. I just purchased their ZD3 Dac PreAmp and their complimentary ZA3 power amp. Both of which were relatively easy to setup but I want to know if anyone else is getting the occasional snap, crackle and pop line noise you get with playback of older or poorly recorded tracks?
  • I was told it could be interference with the power blocks or that I need to upgrade the power supply for the ZD3 with a 48volt into 10amp which will likely clean up the distortion im experiencing with its default 5 amp supply. Also my blocks are right near the amp & dac so this could be from electrical line noise and insufficient power to accurately drive the second amp dac? im an old school audiophile so not sure what if anything im doing wrong. but would be super appreciative with anyone that has had a similar issue and how they fixed it. thank fosinites for any assist.
euip: zd3 dac preamp with za3 amolifier used in xlr stereo mode not mono at least not yet.
plan to swap out opps with burson vivids but not until I try the newly ordered 48v 10 amp power supply on the ZD3 - help noise is driving me bananas.
thank you all
