ygafosi
Hi Fosi Audio Team,
I am building a custom Passive High-Pass Filter (using inline capacitors) to protect my satellite speakers when using the V3 Mono in a 2.1 setup.
To calculate the correct capacitor value (C) for my desired cutoff frequency, I need to confirm the Input Impedance (R) of the V3 Mono.
Could you please provide the following:
Thank you for the support and for a great amplifier!
- XLR/Balanced Input Impedance: What is the impedance per leg (Pin 2 to Ground and Pin 3 to Ground)?
- Is the impedance fixed, or does it change significantly depending on the position of the volume/gain settings? My Gain setting is 28db
