I went down the rabbit hole trying to find an amplifier with a tight budget of $230. Sounds simple, right? It wasn’t.
At first, I did what everyone does—I looked at the “safe” brands. Yamaha, Sony, NAD, Marantz. New and second-hand. On paper, it felt like the right direction. In reality, it was compromise after compromise.
Some were just too big—half a desk gone for one piece of gear. Others didn’t even have a remote. Some had no Bluetooth at all. The second-hand ones? That was another story. Scratches, worn-out knobs, questionable history. And let’s be honest, a lot of them were just old. Not vintage in a cool way—just… old. The kind that need new capacitors, resistors, and a full service before you can even trust them.
I actually have a NAD 3140, and that alone was enough to make me think twice. Same for the old Acoustic Solution AV-40 MK2 speakers. It sounds good, sure, but it heats up like a stove and clearly needs a full restoration. It takes space, it demands attention. It’s not something you just “use.”
So I kept digging.
That’s when I started running into these newer Class D amps. Brands like Nobsound, Douk Audio, Aiyima, SMSL, Topping, WiiM, and Fosi Audio. I’ll be honest—I was skeptical. Small boxes claiming big power, low distortion… it sounded like marketing more than reality.
So I did what anyone does—I went deep. YouTube, Reddit, forums. Hours of reviews, comparisons, and people arguing in comment sections. Slowly, I started filtering things out. Models with issues, brands with inconsistencies, overhyped stuff that didn’t hold up in real use.
What remained were a few solid options. And that’s how I ended up looking seriously at Fosi.
Even then, it wasn’t straightforward.
First, I looked at the V3 Mono. Impressive on paper, but then reality kicks in—you need two units, two power supplies, and a preamp because there’s no volume control. That’s already turning a simple setup into a project.
Then I checked out the ZA3. That one made more sense—volume knob, solid design. But no Bluetooth. And for me, that mattered.
I was stuck between good options… but not complete.
And then I noticed the BT20A Max.
At first, it was just another model on the page. But the more I read, the more it started ticking boxes. Bluetooth 6.0 with LDAC, subwoofer out, proper power, compact size, remote, 12V trigger… it just kept covering the things I actually needed in real life, not just on paper.
That’s when it clicked—this one made sense for my setup.
I needed something small for my living room. Something that could drive my ELAC Debut 3.0 DB53 and a subwoofer (ELAC DS103), without taking over the space. At the same time, I wanted something flexible enough to move around—use it at my desk if I wanted, replace the NAD when I got tired of dealing with it.
I set it up with the ELACs, connected everything, hit play… and just sat there for a second.
Because it didn’t make sense.
This small, lightweight box had no right to sound like that. The control, the clarity, the way it handled the speakers—it wasn’t struggling, it wasn’t “good for the size.” It was just… good.
The bass was tight and clean, not bloated. The mids were clear, and voices sounded right. Highs had detail without becoming harsh. And the overall feeling wasn’t “impressive”—it was comfortable. The kind of sound that makes you stop testing and just listen.
Then I added the sub through the dedicated output, and everything locked in. The system suddenly had weight and depth, but without losing control. No boom, no mess—just a full, balanced sound.
After that, I tried going back to the NAD for comparison. And for the first time, instead of thinking “this sounds more serious,” I started noticing the downsides. The heat, the size, the maintenance, and the fact that it demands effort.
The Fosi doesn’t.
It just sits there, does its job, and gets out of the way.
And that’s probably the biggest surprise in all of this.
I wasn’t looking for something revolutionary. I was just trying to find something that made sense within a budget.
What I found instead was something that made me stop overthinking the gear… and just enjoy the music.
So I kept digging.
The Fosi doesn’t.
