Hello!
I just replaced the op-amps inside the ZA3 with 3 MUSES02s; they sound amazing!
However, upon reassembly, I noticed the volume knob doesn't stop at zero; . I don't even remember if it ever did, but it works fantastically nonetheless.
Is it supposed to stop at minimum, and if so, how is the best way to tighten the nut and washer to do so?
Thank you so much!
Yours,
Maya
Thank you so much!
Yours,
Maya
