To connect two Fosi Audio ZA3 units in mono configuration to the Fosi Audio LC30, follow these steps:
First, prepare eight sections of speaker cables of the required length: four will be used to connect the ZA3 units to the LC30, while the other four will connect the LC30 to the speakers. If you place the amplifiers above or below the ZA3 units, four sections of 20-25 cm may be sufficient. For the connection, it is preferable to use banana plugs, as they are very convenient.
Connect two sections of cable from the right channel of the first ZA3 amplifier to the left input of the LC30 amplifier A, ensuring correct polarity. Repeat the same procedure with the second ZA3 amplifier, connecting it to the right imput.
Once the two ZA3 units are connected to the LC30, all that remains is to connect the LC30 to the speakers using the speaker 1 output.
