dennycranium
Hi
Firstly, I searched online for an answer to my question(s)
I have two fosi audio za3's
I want to hook up the second one in and use it in mono. I also have a powered sub.
I currently use one amp in stereo and XLR input.
The instructions in the manual only show how to hook up using RCA cables. (for mono)
What is the procedure for running two ZA3s in mono using XLR inputs? Is it the same procedure as RCA cables just using XLR inputs?
I also have a powered subwoofer. Do I just use one of the subouts from one of the amps?
I use an SMSL DO200 DAC, which has a sub out. Should I use that one?
This is my signal path- USB C from my computer to SMSL PO100+/to SMSL DO200 using I2S input/XLR out of DO200 to Fosi PK01 XLR input. XLR out of Fosi SK01 to XLR into 1 ZA3 in stereo mode. (You can see why I want to continue using XLR.) (I also plan to do an XLR opamp upgrade using 3602.)
Many thanks!!
Many thanks!!
